BP Ultimate 102 RON fuel
Re: BP Ultimate 102 RON fuel
How can they justify that price when Tesco puts out 99 at less than a quid?
matt_mr2t wrote:How can they justify that price when Tesco puts out 99 at less than a quid?
As i said above, because it's race fuel.
The old leaded petrol was 100+ and didnt cost that much.
I'm told if you dont have a cat you can run leaded fuel and some places apparently still sell it?
matt_mr2t wrote:The old leaded petrol was 100+ and didnt cost that much.
I wouldn't, it's something to do with the valve seats.
Mark Edwards wrote:matt_mr2t wrote:The old leaded petrol was 100+ and didnt cost that much.
I wouldn't, it's something to do with the valve seats.The lead would wear them away or something like that.
The Lead prevented valve seat erosion I believe, new engines have hardened valve seats to deal with UL.
The Leaded fuel will do your Oxy sensor no favors though.
Parting thought, BP102, Wonder how well this stuff ages in the tank?
Paul
What I find so amazing
is that people think that by filling up with this stuff, they are going to gain power
You need to have a different map, which will obviously suit some people on here with Motec or other aftermarket management, but for your run of the mill Rev 3 running a bar of boost, it isn't going to make any difference, except lighten your wallet.
RichardPON wrote:What I find so amazingis that people think that by filling up with this stuff, they are going to gain power
not strictly true.
with 102 I would imagine you could tweak a little more agressive on the timing too and still not see as much det
Car now Sold
damn 5th Lumber Disc
Techinically you will get more power.
Or for want of a better phrase
- you'll find power you lost through not having proper fuel.
With lesser fuel's the ecu will automatically retard timing losing you power.
With better fuel it'll be less intrusive letting you see better potential.
This was proven on 5th gear in quite drastic fashion on a Jap spec Scooby STi.
Coppycat
but you put it SO much better
=D>
Car now Sold
I can quite clearly feel a difference between Ultimate 97 and Tesco extra value rocket fuel.
But Scoobies have active knock control.
Do MR2 Turbos?
Do MR2 Turbos?
Well they have knock sensors that react to knock by pulling timing if thats what you mean?
I'm in the dark here on this one.
They actually have knock sensors, as opposed to CPS/Phase sensor combos?
Nope, proper knock sensors that screw into the block that are linked directly to the ECU.
Right, fair enough then!
just put half a tanks worth of 102ron bp fuel in my car and my butt dyno tells me the car is definately quicker,the back end was starting to lose traction in 2nd gear under hard accelleration,it also feels more responsive a bit like driving on a freezing winters day.My knock readings are playing up at the moment normally no matter what I do they normally max at about 45 but lately while poodling along I've hit 60 and I'm only driving on part throttle and 0.5bar of boost,I then floor the car at 1.2bar of boost and get a knock of 40,so something not quite right there,hopefully be remapped this week.With the 102 ron fuel I still get the odd spike on the knock upto 60 when I'm driving gently,but under full throttle high boost Knock has dropped down to roughly 25 which is quite a big drop.
If BP keep this fuel available long term then I may have to invest in a motec ecu so I can have a map especially for this fuel as I think it's good stuff,in the mean time I'll use this fuel every other time I need to fill up.
Watch out OZ here I come
Couldn't you get more power when running 102RON by upping boost a bit
splash2 wrote:Couldn't you get more power when running 102RON by upping boost a bit?
Only if you match the fuel to the boost other wise you'll run lean
You can now buy the Apexi Excell software,so i think you'd be able to download various maps to your PFC.
http://www.nengun.com/catalogue/product/343
