Matt_J wrote:Thats a fair bit cheaper than the 1350+vat that fensport charge
tim_chick wrote:I guess you have seen:
www.billzilla.org
Everything I have read seems to suggest 140bhp for 20v silver top, and
145 for blacktop, rather than the figures Toyota claim.Does anyone have dyno results for the 20v?
Tim
waynestoyotamr2 wrote:Matt_J wrote:Thats a fair bit cheaper than the 1350+vat that fensport charge
Spend a few hundred extra and you'd get yourself a whole SC from Jap auctions for that kind of money!!!
tim_chick wrote:Everything I have read seems to suggest 140bhp for 20v silver top, and
The biggest gain your going to get out of your 20v is via a standalone.Why? because the stock 20v computers run VERY conservative ignition mapping.
On some parts of my ignition map, you can see that the total timing is 42 degrees and I never ran it lean/detonated/pinged ever.
Though the car was tuned slightly conservative with these ignition maps
(12.5:1 vs a normal 13:1 A/F) I really like the megasquirt units, I also have my maps on the internet that you can load up right into your unit, and then you really wont have a need to tune it.
I can also supply these units with upgraded resistors and a CNCed case for around
$280 shipped in the USA.
( email me [email protected]
luthor1 wrote:FYI, balancing does not increase the rev-limit on an engine..
unless it removes a bothersome frequency, and even then only by 50 or so rpm.
If you balance it and then set 9300rpm limit, that's fine, but it would have done 9200 MINIMUM before the balancing anyway.
(reference: David Vizard: Tuning BL's A series engine, chapter on general theory about engine balancing)
Grinding the crank lobes thinner to reduce the centripetal force on the oil preventing it"flinging" off at high rpm is a better idea.
Oh obviously don't go too mad otherwise you will reduce the strength of the engine.
luthor1 wrote:I totally agree that lightening and balancing is the cornerstone to proper internals rebuild, especially if you are running new pistons/rods/flywheel and are intending to rev it hard.
However, if it is balanced to run 7800rpm(standard) then it is balanced to run 9500rpm.
Further balancing of one that is good for 7800 will
*not* make it good for 10k.
What you may find is that balancing allows it to run
"longer" at high revs due to less internal friction, which is a good point.
Lightening and balancing will improve POWER, ACCELLERATION and MPG for free basically.
Power and MPG due to less internal friction.
The failure(if you revved a 1.6 to internals failure) would probably be a broken con-rod, or lack of lubrication to the main bearings.
JMR_AW11 wrote:
I've heard reports the stock engine can take well over 9000rpm in short bursts.I don't think I'm going to volunteer to test this on my engine.
JMR_AW11 wrote:
I turned up the rev limiter in my reprogrammable 4A-GE ECU and let the engine rev past 8000rpm.I've done this twice now.
Both times in second gear.
The engine goes eerily smooth at 8000rpm but it sounds like it is revving much higher as it really screams.
It also showed no signs of wanting to stop revving higher.
My car is mapped to remove the overfuelling above 6000rpm and the power curve on a dyno keeps climbing past 7200rpm.
I didn't dare take it higher than about 8200rpm.
PsychomIKE wrote:waynestoyotamr2 wrote:Matt_J wrote:Thats a fair bit cheaper than the 1350+vat that fensport charge
I think the main advantage are that these are later MAP sensored units and come standard with 20+ bhp more than the mk1s 4AGZEs rather measily 140 ish bhp.
Also be mighty surprised if you can get an imported SC'r for a couple of grand plus VAT but there you go
The general consensus seems to agree with you on those figures but that it could be possible to really open it up with after market engine management and a set of cams.This is from the club4ag boards, those guys know their stuff.
So who knows what is possible with it.Unfortunately when the guys in the US want big power from these engines, the only place i think these swaps can be considered at all common, they nearly always turbo/supercharge them so it really is hard to find out how much is possible whilst keeping it naturally aspirated.
The thing for me with considering those 20valves was the lack of weight added to the car, especially at the rear.Imagine just 170 or 180 bhp at the crank with no extra weight.
*drools*
Mike
Pity the engine someone( Paul Woods
) recently
'tested to destruction' didn't have one of your ECUs on it to see at what revs it went pop
JMR_AW11 wrote:If anyone could get me a 20V ECU I could probably dump out the ROM from it and publish the stock 3d ignition map.
