MartG wrote:Lauren- if you remove the ABV how does the engine breathe when the SC isn't running
? Apart from its function of controlling max boost under ECU control
( which is disabled by the mod detailed here http://www.mr2sc.com/websites/tech/abvlines.htm
), it opens to bypass the SC when it isn't engaged allowing air to pass straight between the throttle and the inlet manifold.
Correct!
