My 400whp saga, 373whp after mapping.
Draven
Re: My 400whp saga, 373whp after mapping.
Post by Draven »
Ryan S wrote:I still need to collect the filler neck anyway so no mad rush!!
no mad rush? did i understate my level of excitement
Ryan S
Post by Ryan S »
Hahahah!! I know I know, The real rush will be running in the engine! As soon as the car's MoTd I'll be using it ad my daily driver. My daily routine can see me doing 120 miles in a day so shouldn't take long!
Ryan S
Post by Ryan S »
Right, So managed to get away from work. The short story is i'm not getting a spark. I get spark when testing the coils (plug out, Spark confirmed) but no spark when cranking. The ECU is recieving signal to fire the coils but for some reason isn't. The wiring is right as the coils wouldn't fire under test. It's a head scratcher but we'll get there :)
Ryan S
Post by Ryan S »
Coolant neck on. Think we've figured out what the issue is so hopefully get it fired up tomorrow.
Ryan S
Post by Ryan S »
So, The car fired up, Run for about 5 seconds and conked out. Can't get it to fire up again. Pulled the plugs, They were wet. Dried them off and put them back in, Still no joy. I thought it maybe timing related (it's deffo not 180 out) but I'm getting no splutters at all, Keep in mind it already started (and actually sounded quite smooth). So god knows what's going on.
Ryan S
Post by Ryan S »
https://youtu.be/Hefgno9oTkA
https://youtu.be/WPNxDwNIZrE
She lives and sounds incredibly throaty! Exhaust is split new though.
Rory
Post by Rory »
Nice one!
My MR2 for sale! Check out the for sale section
Ryan S
Post by Ryan S »
Yeah well chuffed!! Obviously it's idling way too high and it is running rough. The timing does need set properly and I'm still waiting on my map sensor arriving. But hey! It starts up at least!
CalMac
Post by CalMac »
Awesome stuff mate :thumleft:
So is yours also Renault liquid gold? I thought I was the only one :lol:
Ryan S
Post by Ryan S »
CalMac wrote:Awesome stuff mate :thumleft:
It is mate yeah! Suits the mr2 so well!
Draven
Post by Draven »
Nice work :) i'm glad to hear it running. its mean.
Ryan S
Post by Ryan S »
Draven wrote:Nice work :) i'm glad to hear it running. its mean.
Yeah sounds great eh! Sounds like racecar :) My map sensor arrived tonight right before I left for work. Will get this wired in tomorrow and get coolant bled. I've been too afraid to let the car idle for any length of time without the map sensor plugged in. With a bit of luck I'll be on the road next week :)
Ryan S
Post by Ryan S »
So car is now idling beautifuly, I've bled the coolant system (which was bone dry) and have decent heat from the heaters. Very annoyingly i have a small drip at the coolant sensor (the dash one) so I'll probably get a new sensor. I've bodged it up with ptfe tape for now. The car does take a while to start when cranking and is over fuelling when revved so I'm hoping it's just a case of tweaking some settings, The link ecu doesn't seem to be able to see the other coolant sensor which is brand new. Again hopefully it's a daft setting in the ECU. Tomorrow I'll be bleeding the clutch, I've run the car up to temp a few times now and all appears to be ok. I want to do away with the coolant overflow bottle but I'm not sure how so I'll start another thread about that.
Ryan S
Post by Ryan S »
So, I Changed the fuel system back to a normal return today reloaded the map to the ECU. Whatever my issue was is now gone . Changed the settings to my own map sensor. And other than a tiny wee flat spot on throttle the car is running really well. With a bit of luck my coolant bottle will arrive tomorrow so I can install it then take the car for an moT when i have time. Very pleased with myself :D As stated already this map is just to let me get 1000 miles on the car before changing the turbo, fuel pump and intercooler.
https://www.youtube.com/watch?v=5QuCsSx-CTU
Rory
Post by Rory »
Sounds good. I bet you can't wait to get that finished
Ryan S
Post by Ryan S »
Rory wrote:Sounds good. I bet you can't wait to get that finished
Yeah man! Went to take it out the other say and found a small leak from the fuel rail somewhere. So away investigate that today first and replace whatever needs sorted. Frustrating to say the least haha!
Ryan S
Post by Ryan S »
Just been out to check my leak, I've cracked the rail 🙄 Thankfully my mate has a spare so will get it sorted after xmas.
Ryan S
Post by Ryan S »
So I've managed to get my turbo back so I'll deffo be using the one I originally bought from AGP. I keep looking at turbos and keep coming back to that one. So I'm glad I managed to get it back. It's oil fed only so I'd only need to reroute the water line back into itself (literally a length of pipe) and change the oil line. I had a Vband downpipe for it and it was about 1 inch away from fitting so very little modification required there. Over the holidays I'll get the fuel rail sorted and get it away for an MoT.
Turbo specs here:
55lbs / min approx 525 horsepower
S252 AKA 52/61 AKA 52-61 SX-E
BorgWarner Turbo Systems Aftermarket is pleased to announce the release of the AirWerks® SX-E super core assemblies for performance applications. These new part numbers are purpose engineered for both diesel and gasoline high performance applications.
S200 SX-E super cores contain the following exciting new features:
- Compressor cover integrated speed sensor port and pre-machined boost port
- Forged milled (billet) compressor wheels with extended tip technology
- Optimized compressor stage aerodynamics
- Interchangeable with existing turbine housings for upgradability
The BorgWarner super core assembly consists of the compressor cover attached to the cartridge, all cartridge to turbine housing mounting hardware, clamp plates, cap screws and mounting gaskets. Speed sensor and turbine outlet V-band are not included with turbo assemblies. Choose a turbine housing from our extensive list of factory housings as well as our custom cast performance housings.
Compressor Specs:
- Borg Warner 3.5" Inlet 2" outlet compressor housing with port shroud map width enhancement, pre tapped for speed sensor and pressure port. (parts not included and will need to drill through)
- 52.17mm inducer 69.5mm exducer FMW Forged Milled Wheel (Billet)
Turbine Specs:
-61mm exducer, 70mm inducer turbine wheel
-T3 Open Scroll turbine housings available: .63, .82, 1.06 A/R with 3" V band outlet
Mine is the .82a/r.
androo007
Post by androo007 »
I've got a spare rev 3 rail mate, shout if you need it.
Ryan S
Post by Ryan S »
androo007 wrote:I've got a spare rev 3 rail mate, shout if you need it.
Cool man, If I end up stuck for whatever reaon I'll give you a shout. You don't have the spacers between the head and rail do you? I am waiting on Toyota phoning me tomorrow but had nothing but bother with them lately!
