My first Mr2 project
Re: My first Mr2 project
Good bit of work going into this, some nice bargains you got too
FORGED BUILD (424hp @ hubs): http://www.imoc.co.uk/forums/viewtopic.php?t=170916
Yeah got some good deals like the japspeed exhaust I got for free with the boot lid, just seen ur from Glasgow I'm from beside Aberdeen
EDIT: afaik rev3+ is 8bolt, rev2 is 9bolt, and rev1 could be 7bolt (I will wait to be corrected)
Gullzter wrote:EDIT: afaik rev3+ is 8bolt, rev2 is 9bolt, and rev1 could be 7bolt (I will wait to be corrected)
Thanks for the response, went on the link and it doesn't say anything about 6 bolt, hoping there will be a way to make it fit
I thought it was 7 bolt, just assumed that the top right of pic was missing and that may have a bit for bolt?
Don't know what rev that exhaust is for as just tried to fit it and all the holes are out of line and the ports don't match up
Yeah was about to say it looks weirdly different but i didn't know any were 6stud, I guess the n/a head are nothing alike then
Just won some more bits on ebay, phoneix power rear spats, toms skirts and winglets and bomex front bumper for £100 just need to collect them
Had a few hours free today so got the grinder out and wire brushed under neath the boot floor and rust treated any bits needed. Then covered it all in zinc primer ready for the stone chip whenever it turns up. While grinder was out I cut the bolts holding the struts off and chapped the bolts out. Anyone know what thread and length they are so can order some from ebay?
Just waiting for stonechip and springs then can get subframe on and finally get it back together
That's a lot of work done and fair play for saving the car. Keep up the progress and I will follow with interest.
Gave up on the stainless manifold, so I've drilled out the snapped stud and refitted the manifold
Also had to cut the alternator off with a grinder and drill out the threaded part of the bracket. Will now be able to fit the alternator but the top adjusting part was missing so I dunno what it needs there?
Got my shot blasted exhaust mounts fitted aswell, 1 of the bushes needed replaced so made a polybush for it
Kudos for jumping in at the deep end on it!
I have skirt envy, they're a bargain! Should you no longer require them let me know
Magic Beans wrote:Kudos for jumping in at the deep end on it!
Thanks, will keep u in mind but looking forward to fitting them lol
