I found another mr2 with missing MOT mileage. Clocked back maybe?
SonicSW20
Re: I found another mr2 with missing MOT mileage. Clocked back maybe?
Post by SonicSW20 »
Rust inside the arches, and rust inside the sills are the two main areas that can be hard to spot unless you get it in the air, and for the sills you need to remove the interior panel that covers the seatbelt and have a good look inside the cavity.
mr2_maverick
Post by mr2_maverick »
[quote="Gazza_DJ"]Rust inside the arches, and rust inside the sills are the two main areas that can be hard to spot unless you get it in the air, and for the sills you need to remove the interior panel that covers the seatbelt and have a good look inside the cavity.[/quote]
Hmm not sure if someone will be happy with me dis-assembling their cars. I'm not even sure how to so even id be scared to break something.
mr2_maverick
The rev4 3sge is still a non-interference engine right?
aussieGT
Post by aussieGT »
mr2_maverick wrote:The rev4 3sge is still a non-interference engine right?
Yeah, Rolf Harris hasn't been anywhere near the engine, definitely non interference.
SonicSW20
Post by SonicSW20 »
Yeah, all 3S's are non interference apart from the BEAMS NA's.
