Time for another update
- exhaust related again
I thought I was happy with the single exit I made.
.but actually as time went on I really missed the unique engine note that the MR2 has with such a short overall exhaust.
I have always been a fan of how the Berk Technology system looks but in recent years the cost of new exhaust systems has skyrocketed and it's been hard to justify the cost.
I guess there comes a point when you cave in though.
I ordered up a new Berk system from TarmacSportz and I have to hand it to them, it only took a week to arrive from the date of ordering, top job.
It arrived in great packaging so I thought I would share some photos of how well it was protected.
There's no getting away from what a great looking system this is.
There's often a lot to say about the fit and build quality of Berk exhausts for the MR2 and admittedly I did struggle a little to get the exhaust hung on the rear mounts
- a little bending of the hangers on the exhaust to get the holes aligned and a bit of leverage to get the bolts in.
I would say overall I wasn't disappointed, I just wasn't as impressed as I should have been having spent
£860 on an exhaust.
I can't argue with the positioning and fit once all assembled though.
It's perfectly centred and looks surprisingly subtle
(for a chrome exhaust).
Here's some more pics:
Here's an interesting comparison with my original Japspeed system, just to see the difference in muffler size! This Japspeed exhaust was the same exhaust I replaced the tips on after my crash and also opened up to replace the silencing material
(this did not work well and was deafening after).
While the car currently has a Berk decat pipe, I'm getting tired of the stress emissions brings me every year and just want some peace of mind that I've done all I can to make the car legal emissions wise.
I also would like to remove the drone while cruising on the motorway/long A roads and I think the original cat will help a lot with that.
So I've been assembling an original catalytic converter for the rev3 turbo.
The cat you see in the photos is a mix of a ct20b elbow and a rev2 turbo catalytic converter section which was in great shape and I have to thank Andrew at JSpec in Scotland for supplying this and taking a damaged cat I was sent to offset the cost.
Andrew is a great communicator and a pleasure to do business with
- I have no doubt I will buy much more from him over the years
(as it goes he's supplying me with all the A/C pipes to rebuild my A/C system, but I'll save that for another post).
Here's a photo of a complete MR2 turbo exhaust system:
Here's also some photos of the old system which I made myself and was on the car for around 2 years I think.
I did try to fit a cat in but it was just too far away to get hot enough to function, although it did go some way to pleasing the MOT tester.
Interesting to note the difference in weight between the two systems.
The Berk system is 15kg exactly.
The system I made is 20kg.
However, the system I made carries 16-17kg all at the back in the silencers/cat/pipework, compared to the Berk exhaust which probably carries only 11-12kg over the back in the mufflers and pipework.
My system also hung a lot further back and I'm convinced was upsetting the balance of the car with the springs and dampers I have fitted.
.but that's probably just placebo!
Here's a quick snap of the Berk system on the car.
I need some advice on whether to keep the metal grill which runs between the exit pipes, or whether to cut it off and preserve it in case I want to put it back on in the future.
At the moment I'm leaning toward cutting it off as the exhaust looks so good now! What do you guys think?
I'm also contemplating selling the exhaust system I made, however it is mild steel, quite corroded in places and not to everyones taste, so even if I wanted to I'm not sure I would be able to
If you do like it though, get in touch.
