You should have a metal ring than fits against the piston and seals it.
shinny wrote:You're missing a bit!
http://3.bp.blogspot.com/_8T0m6w7_pvY/T ... om+USA.jpg
dylan5084 wrote:As soon as I got the email I clicked! Have just fitted the ring and it's back to nice hks superdragger noise! What a mug!
Kinda wondered why there was a spare ring..
Cheers lads!
Can go to lanzarotte tomorrow now and not be wondering what I done wrong lol.
C35Rob wrote:have you thought about putting some heat shielding around the hot pipe where the wastegate sits just below it?
something like this![]()
http://www.demon-tweeks.co.uk/motorspor ... d-material
Milo_101 wrote:In my humble opinion, an adapter would make much more of a clean install and offer the same advantages, maybe except for cost.
something like this.
shinny wrote:Milo_101 wrote:In my humble opinion, an adapter would make much more of a clean install and offer the same advantages, maybe except for cost.
But a CT to CT external wastegate adaptor like that makes no sense as a product as the market is miniscule..
and even if you could buy one, then none of the downpipe, induction, intercooler pipework, oil feed and water lines would line up.
Given his available skills, I think Dylan has absolutely taken the right direct for externally gating a CT series turbo.
dylan5084 wrote:Cheers shinny![]()
building boost really slow now though, 5k rpm for full boost, it used to be 2600-3k for 1 bar.
It's holding boost at 1 bar now which is great.
I don't know if the internal gate is cracking or not is there any other way to stop it, maybe putting a spot weld on the actuator rod?
C35Rob wrote:Do you have access to a mityvac tester? You really need to find out which waste gate is either opening or leaking before doing anything else
