markstevieandmads wrote:So why did Toyota put a OEM bov on it in the first place?
For emissions and to stop the turbo making fart noises between shifts
The ST185 GT-Four has the same 3sgte as the SW20.
mr2magic wrote:I'll just leave this here:
http://www.themotorhood.com/themotorhoo ... he-experts
You don'tneed
it, but it's cheaper than buying a new turbo if and when it lets go.
just my 0,02
jimGTS wrote:androo007 wrote:But there has to be an acknowledgement that it does put more stress on the turbo than running one..
.plenty of people have poped turbos very quickly without one
(outside the Mr2 community).
sorry your not going to get that acknowledgement from me.
its a BS myth.
there is no evidence anywhere online to back up the theory it will blow your turbo.
Al-sw20 wrote:Except it's not compressor surge.That happens under load.
mr2magic wrote:Al-sw20 wrote:Except it's not compressor surge.That happens under load.
Who on earth told you that?
Here from Garrett:
Turbobygarrett Welcome to Turbobygarrett
Become a Gearhead![]()
Where to buy![]()
Product Catalog
About Us
Products
Turbo Tech
You are here
Home> What is compressor surge?
A.The surge region, located on the left-hand side of the compressor map
(known as the surge line), is an area of flow instability typically caused by compressor inducer stall.
The turbo should be sized so that the engine does not operate in the surge range.
When turbochargers operate in surge for long periods of time, bearing failures may occur.
When referencing a compressor map, the surge line is the line bordering the islands on their far left side.
Compressor surge is when the air pressure after the compressor is actually higher than what the compressor itself can physically maintain.
This condition causes the airflow in the compressor wheel to back up, build pressure, and sometimes stall.
In cases of extreme surge, the thrust bearings of the turbo can be destroyed, and will sometimes even lead to mechanical failure of the compressor wheel itself.
Common conditions that result in compressor surge on turbocharger gasoline engines are:
You don'tneed
just my 0,02
mr2magic wrote:
-A compressor bypass valve is not integrated into the intake plumbing between the compressor outlet and throttle body
-The outlet plumbing for the bypass valve is too small or restrictive
-The turbo is too big for the application
Turbo
Q.What is compressor surge?
mr2magic wrote:AFM= Air Flow Meter
Pre'93 mr2 used these whereby the infamous
'don't touch the screws' with regards to disconnecting the wiring was born
