gnzyza wrote:It won't be throttling back back all the time it's on only when it detects slip.So it will give the full amount until one of the wheels loose grip.
MartinF wrote:gnzyza wrote:It won't be throttling back back all the time it's on only when it detects slip.So it will give the full amount until one of the wheels loose grip.
Which on a dyno will be 100% of the time.Also RLTC doesn't throttle back it cuts the fuel.
Anyway what the hell kind of outfit dyno's a car with the traction control on?Sounds like a place to avoid IMO and as for the c o c k and bull about them not having time to flick a switch then run it again, I hope the OP used the same excuse when they asked him to pay.
MartinF wrote:They should have realised it.Your car won't be the first they've tried to dyno with the traction control on and it's obvious looking at the trace that something's not right.
You're paying for their expertise as much as time on the equipment
gnzyza wrote:MartinF wrote:gnzyza wrote:It won't be throttling back back all the time it's on only when it detects slip.So it will give the full amount until one of the wheels loose grip.
I know that, I was replying to the OP when he said"Well at least now i know how much power im running with it on"
to ME implied he thought with it on his power is reduced 100% of the time
QUOC2008 wrote:so does this mean with traction control ON mean 25% power cut equal to 470bhp minus 25%-117.5bhp equals 352bhp TC ON?
2mad wrote:The hole point of tc is to give you the most amount of grip for the situation.
wouldn't use it on a dyno tbh
its more about how fast you can pull out a damp corner leaving your foot flat letting the tc do the work
Like gazza said far to many variables..
a true real world test.
do a damp lap round the block tc off and one tc on
see what the difference is like
Must admit its a bit strange to me how intrusive it was on the dyno![]()
2mad wrote:Must admit its a bit strange to me how intrusive it was on the dyno![]()
QUOC2008 wrote:I know true..
thats a real test but just wanted to know a estimate.
any thanks everyone for the feedback
Nic wrote:2mad wrote:Must admit its a bit strange to me how intrusive it was on the dyno![]()
It was intrusive on the dyno because the front wheels are not turning
