FYI I have had my Mk2 since 2002 when I bought it as a Rev2 N/A with a 3SGE engine in standard trim putting out 154bhp.
In the first 5 years, with the aid of a Buddy Club ECU
(pre-programmed Jap import kit
- can't be mapped) stainless exhaust, Apexi cone filter, de-cat and fresh dizzy cap
/ rotor arm, I attained a bhp reading of 171bhp at the flywheel on a well regarded dyno test rig.
Long story short, the piston rings got stripped due to incorrect masking by a powder coating company who did my cam cover and intake manifold.
I sourced a low mileage Rev3 Turbo donor car that had been front end smashed for
£750.
I then paid Toyota GT
(now JDModified) to do the conversion
(cost about
£1200 for the labour including new clutch, cam belt and fixing some broken manifold studs).
Whatever you may have read about them from certain members on MR2 boards, I cannot complain about the standard of work performed on my car.
The wiring is fine
(I've stripped large parts of the car subsequently and never found anything alarming), the engine runs perfectly and has done in the 7 years since they did the conversion with 1 split hose being the only issue that wasn't anything to do with their work.
So my experience is, firstly, don't chuck money at an N/A
- I definitely felt improvement with what I did to it but it was not going any higher without serious investment.
Secondly, the standard Rev3 Turbo driving experience blows the 3SGE out of the water
- no exaggeration whatsoever
- you feel rocket powered.
Lastly, if you get a good garage to do the conversion you are unlikely to experience any issues.
Lastly though, I've had a fair amount of welding done on my cars sills as it is a UK car and previous owners have obviously done plenty of salt driving and the rain hasn't helped.
If I were to do it again I would get a Rev3+ turbo and not faff around spending extra having a UK car converted
- it isn't worth it unless like me because you are attached to a certain car.
The benefit is that it will save you plenty of money, be worth more than a hybrid body
/ engine coupling if prices do go up and lastly there will be hopefully way less corrosion issues if you get one that has been undersealed after import and not driven in the salt.
