yeah steph's delimiter still does power on self test, and it's off aswell, 40( shows45) 80(shows 85) 0
i'll play with that cheers.
Peter Gidden - SBITS wrote:braided lines missing pin to stop it wobbling(passed 2 years in row without issue, maybe got lucky thosie times)![]()
Brake hoses should be secured both ends.
clocks don't have kph as well as mph![]()
Not part of MOT test.
fog light mod not passing due it not being 100mm away from brake light.![]()
turbo timer not allowed.![]()
http://www.motinfo.gov.uk/htdocs/m4i00000001.htm
pope_acute wrote:Peter Gidden - SBITS wrote:braided lines missing pin to stop it wobbling(passed 2 years in row without issue, maybe got lucky thosie times)![]()
yeah you are right, but in Northern Ireland it's different they have their owns rules/regs i think.
Peter Gidden - SBITS wrote:MOT test in N.I.is same test as rest of UK except:
1.) that tests can only be carried out by the ministry in their locations, so there is only a very limited number of locations that you can go for a test.
2.) You are required to display the MOT on the windscreen.
Neither of which cover the tester being an ar$e.![]()
Either appeal or go elsewhere.
