jimGTS wrote:Nothing wrong with green
alan_uk wrote:How did you guys get the squares for the redline so perfect?
alan_uk wrote:have any of you guys changed your speedo bulbs to green led's or done the mod like shinny using the gel sheets and gone green
alan_uk wrote:true
on the plus side i have a rev5 so was thinking of matching up the rev5 clocks to the gel
so everything that looks red during the day have light up red and the numbers which are white light up green if that makes sense
so therefor i wouldn't need to cut out the squares, good compromise:)
and would still look good i reckon
jimGTS wrote:its really isnt too difficult.
its trial and error with a torch for checking.
all you need to do is slide/tape the film between the unit and the top cover.you dont need to remove the needles or anything.
shine in a torch so you know its covering the numbers and anyway you go.
it is a little time consuming, so i cant imagine anyone is going to do it for you, is xmas after all!
Torero wrote:That looks fine Alan but 95% of it will be wasted, maybe contact the seller to see if you can get a smaller sheet.Something around the size of A4 is still more than enough.
shinny wrote:The other thing you might find with LED back lighting of the rev5 dials is the red becomes a little more pink.Others have corrected that with a bit of red gel to help the red truely be red
