nickg07 wrote:If you have a budget for a new turbo i say go for it.![]()
if you are going to cry at the roadside if it blows up, then dont do it.
Not one single Noble was fitted with a dump valve.
Adam86 wrote:I just cut the end off a broom and stuck that in the pipe.Done about 7k without issue.
jimGTS wrote:nickg07 wrote:If you have a budget for a new turbo i say go for it.![]()
blows up, how exactly is that going to happen?
JordanR wrote:Adam86 wrote:I just cut the end off a broom and stuck that in the pipe.Done about 7k without issue.
Haha this sounds amazing
nickg07 wrote:jimGTS wrote:nickg07 wrote:If you have a budget for a new turbo i say go for it.![]()
Im just erring on the side of caution.If he can afford a rebuild go for it.
If it does blow up and he cant afford it well.
Why will it blow up? Probably because its a 20 year old Mr2 with a mass produced turbo that will be getting closer to its last legs anyway?
For some reason Toyota saw fit to install a recirc valve on the MR2.To boost longevity and ensure the car gets to 100k miles or near.
Most Nobles were not build with this in mind.
jimGTS wrote:
they are fitted to reduce/illiminate the off throttle surge sound.
nothing more, nothing less.
the st165 and the st185 gt4s, same engine as the mr2, didnt come equipped with a bov from the factory!!
what does that tell you??
nickg07 wrote:But instead of getting 50k miles from it, you might get 20k miles instead
(all totally made up numbers).
