Well 20 psi certainly made a difference!!
Ryan S
Re: Well 20 psi certainly made a difference!!
Post by Ryan S »
moscoworbust wrote:Still unsure why it's so much faster spooling... so weird.
because you've disabled the tvsv, it normally limits the boost in 1st and 2nd gear, when it's disabled, you get full whack. there is now nothing limiting the speed that the boost comes in at. it makes such a massive difference. should feel it on a rev3 :thumleft:
Ryan S
Post by Ryan S »
although at 20psi you were probably putting down about 400bhp :lol:
moscoworbust
Post by moscoworbust »
Nah, when i disabled the VSV and I had the MBC installed initially it was really slow to spool, like it was before i did that.
I had the MBC screwed all the way in and was only seeing 10 psi, at any MBC setting.
Then i turned it again, still slow spool and 10 psi.
Then I took off from some lights and BOOM! 20 psi and instant spool.
I guess the MBC was letting gas past or something and fixed itself by dislodging the spring/ball.
Fun though.
moscoworbust
sheppy wrote:although at 20psi you were probably putting down about 400bhp :lol:
Awesome.
Ryan S
Post by Ryan S »
i'd honestly take it apart and cut a couple of coils off and stretch it, no offence to GTS chris but those controllers are put together like sh*t, the springs are far too big and get caught on the threads etc. there's just too much metal (the spring part) in there for anything to be able to function properly. they are a primitive device but they do work well :thumleft:
moscoworbust
sheppy wrote:i'd honestly take it apart and cut a couple of coils off and stretch it, no offence to GTS chris but those controllers are put together like sh*t, the springs are far too big and get caught on the threads etc. there's just too much metal (the spring part) in there for anything to be able to function properly. they are a primitive device but they do work well :thumleft:
oik mate.
It seems to be working atm, i'll wind it out to 14 psi.
If i have any more issues I will definitely follow your advice.
Magic Beans
Post by Magic Beans »
If only it were that easy to hit 400bhp :wink:
Ryan S
Post by Ryan S »
haha, yeah a slight exaggeration but couldn't have been far off, not a reliable 400bhp by any means, i can be sure there would have been some knock running that boost on pump fuel and a standard ECU :lol:
Ryan S
Post by Ryan S »
moscoworbust wrote:It seems to be working atm, i'll wind it out to 14 psi.
my old rev 2 ran 14psi with a MBC (plus all basic breathing mods) for my entire 5 year ownership and never had a problem once, easily the most reliable car i've ever had, it always puzzled me why toyota never let it come out the factory like this (other than noise/emission restrictions).
Marsh
Post by Marsh »
I recently fitted a digital boost gauge to my rev1 because i am going to install a mbc but my rev 1 already boosts to 12 in 1st and 2nd then 14 in 3rd and 4th?? (Psi) :?:
Ryan S
Post by Ryan S »
Marsh wrote:I recently fitted a digital boost gauge to my rev1 because i am going to install a mbc but my rev 1 already boosts to 12 in 1st and 2nd then 14 in 3rd and 4th?? (Psi) :?:
possibly has an aftermarket ECU, blitz etc....Check the ecu in the boot, it'll be fairly obvious. or it may have a boost controller installed, but that'd be really obvious just by looking in the engine bay :thumleft:
Marsh
Post by Marsh »
Unfortunately it has neither :/ i will be fitting a MBC this weekend though :thumleft:
jimGTS
Post by jimGTS »
nowhere near 400...
maybe 260-280hp at a push at 1.4bar
probably a bunch of torque ie 300+lb, but considering the ct26 cant hold more than 12-13psi to redline, 20psi would have soon turned into 12psi anywhere close to redline.
Ryan S
Post by Ryan S »
then i've no idea why it's running that boost :lol:
Marsh
Post by Marsh »
Nah me either im not complaining as my mates 350 bhp skyline cant pull away :oldtongue:
moscoworbust
I found the same on my rev 1 turbo before I fitted the MBC.
Something is going on.
I'm running 21 psi now, can't seem to turn it down. Well, I can't be bothered. I'll fix it soon.
Kinsy
Post by Kinsy »
'I cant be bothered, I'll fix it soon?'
Do you like driving your car because it will soon be very broken with 21PSI boost. I would be removing it and plumbing the TVSV back in until you fixed your wastegate...
Ryan S
Post by Ryan S »
the tvsv not being disconnected may well be the problem IIRC the MINIMUM boost the car will run without it disconnected is 14psi.
asdrewq
Post by asdrewq »
Driveability i'd guess. Didn't think the populous could handle 1bar in 1st gear :D
Or they were concerned about the monster torque wearing the drivetrain prematurely.
cvega666
Post by cvega666 »
MBC's + already very vulnerable to creep CT26 = neverending boost problems. Mine never stopped creeping, always required very alert right foot, a decent EBC (gizmo, so not breaking the bank) sorted and it was rock solid.
