I want as much tyre on the road as possible, to this there is no argument.
whaddya reckon?
You wrote:.
.when most racing cars use the absolute biggest wheel they can.
You wrote:I want as much tyre on the road as possible, to this there is no argument.
Icsunonove wrote:Errrrrm Formula 1?
djdna2000 wrote:I've heard this said about a lot of cars, but never seen any real explanations given as to why, when most racing cars use the absolute biggest wheel they can.Here are my thoughts:
I want as much tyre on the road as possible, to this there is no argument.Given that the stock
(185/60/14) rolling radius of 577.6 mm isn't all that different from a 255/40/17 combo on the rear
(635.8 mm) and also given that 255/40 tyres have a much stiffer and shorter sidewall, how can it be worse? I suppose the only problem could be the sidewall not offering enough
'give' to keep the whole tyre surface on the road under high-g cornering, though I would have thought this could be sorted with camber adjusting bolts.
whaddya reckon?
tonigmr2 wrote:
OK MK1s I've driven with larger wheels- they tramline horribly, the steering is less direct, the ride is harder and crashes the suspension
(standard mind) and generally the car
'feels' less communicative.
I guess it's a trade off between more
'contact patch' vs.
driver feel.T
Icsunonove wrote:Interesting T.
When I've worn out these 16" tyres, I'm going to sell the wheels.I may buy a set of 15" wheels to replace them then.
(And if you're wrong I'll make you pay for them
djdna2000 wrote:It is, why would you consider that not to be a good idea?(sorry for hijack btw).
