Drilling undertray bolts out
Mullen
Re: Drilling undertray bolts out
Post by Mullen »
Edit... nvm.
Nails
Post by Nails »
Draven wrote:If they drill them out they'll have to rethread them which will mean they will most probably be one size bigger. Unless they use a helicoil which would be rather expensive for the entire under of the car i think.
not if they do it properly. I had plenty to do after fitting my charge cooler and just centred propely. used a good 5mm drill and the remains of the rusted bolt comes out with the drill or the tap. Replaced with 6mm what I picked up from a local diy place.
wenguin
Post by wenguin »
cheers! i'm grab mostly m6 and a handful of larger ones just in case!
anyone confirm the amazon bolts and washers are the right types?
cosmos
Bolts
Post by cosmos »
Not sure if M7 threads are generally available, that size from memory is for brake parts.
Once the middle of the bolt is drilled out the outer threads see a reduction in tension is the idea hence an easy out.
Build up to 4.5mm hole an use the first taper tap and hopefully cut into the original hole.
Good luck.
