2nd Gear crunch
alanmr2turbo
Re: 2nd Gear crunch
Post by alanmr2turbo »
Peter Gidden - SBITS wrote:
alanmr2turbo wrote:is yours a REV1 as REV2+ had ungraded 2nd gear synchro's put in
And...?
Simple question asked
Not everyone knows Toyota upgraded the 2nd gear scnchros in REV2's. So should he have had a REV1 then instead of buying another naff REV1 box he could look for the upgraded REV2 Box.
Mrs Blackpool
Re: 2nd Gear crunch
Post by Mrs Blackpool »
when selecting 2nd gear more often than not i get a crunchy gear selection.
But if revs are low enough it just slides straight in.
only happens with 2nd, no other gears. does this sound like the same sort of problem?
thanks for any guidance
cheers
Liz
MR2 Rich
Re: 2nd Gear crunch
Post by MR2 Rich »
Sounds like the same problem to me. If I go accelerate hard in 1st and go into 2nd it crunches but if I'm very careful and let the revs drop and put it into second it doesn't crunch.
No 2 :(
marshiboi
Re: 2nd Gear crunch
Post by marshiboi »
Hope you get it sorted mate, nothing more disheartening than a dodgy gearbox, ruins all enjoyment of the car :?
leary123
Re: 2nd Gear crunch
Post by leary123 »
marshiboi wrote:Hope you get it sorted mate, nothing more disheartening than a dodgy gearbox, ruins all enjoyment of the car :?
agreed ..my 3rd gear syncro on downshift is horrible...but ive just got used to double de clutching which completly eliminates it. was a pain to start with but ive got in the habit of it now
Kinsy
Re: 2nd Gear crunch
Post by Kinsy »
Double declutching only works for so long though - I wore a 3rd gear synchro down to the point where the only way to not get it to crunch going into 3rd was to go 2nd > clutch in > 4th > 3rd > clutch out :P
Lucky for me ? the car got written off before I had to sort it!
