JSandW2 wrote:I have had many cars pass with a decat fitted
slipping clutch wrote:I believe an MOT inspector is within his rights to fail a car on a visual inspection of the cat having been removed(if it falls into the bracket where it is required)- its not just down to the emmisions test.
An ex G/F of mine had an escort rs and every year it had to have the cat put back on for the M.O.T.
Going on the first bit of information if I'm correct I think Peter of sbits makes a valid point- I.E if it isnt there then it does not matter what the emmisions comeing from the car make technically its a fail and subsequently the ticket issued is questionable.
JSandW2 wrote:Peter Gidden - SBITS wrote:JSandW2 wrote:I have had many cars pass with a decat fitted
http://www.jonrb.com/emoticons/rotfl3.gif
whats up bits?
nickg07 wrote:seen some sports cats on ebay for about 180.saving having to remove the pipe in 12 months is a bonus.
i take it the sports cat would pass MOT still and up the hp a little?
nickg07 wrote:i heard one of the main benefits of the decat was the removal of the elbow with a nicer flowing bit.![]()
how does this look?
http://www.ebay.co.uk/itm/MR2-Turbo-CEL ... 3489397127
Peter Gidden - SBITS wrote:[2)
Regardless of above, it is chemically impossible to pass a full cat test without a cat in place.
Else manufacturers wouldn't bother fitting them.
adamshaw wrote:Dont they go on the engine number? so your car could for instance have a 94 engine in a 96 car?
toxo wrote:You can get very bloody close though.
Kongaroo wrote:So what have people with aftermarket turbo kits been doing to get through the MOT? Have they been custom fabricating a cat into the downpipe?(there goes a few hundred rpm of spool, lol)
Seems rather unfair when the cars have been allowed to run this way legally for so long to suddenly pull the rug out from under your feet- ought to be illegal
Kongaroo wrote:EDIT- btw does anyone know if the original pre-July 1995 rule for CAT emmisions still applies to cars that didn't come with the CAT fitted in the first place?
leenjenna wrote:If he adds the cat for MOT then removes it straight after its passed surely his car is now illegal and insurance policy is void as it is no longer road legal??
Peter Gidden - SBITS wrote:nickg07 wrote:seen some sports cats on ebay for about 180.saving having to remove the pipe in 12 months is a bonus.
Yep.![]()
Sports cats have a larger matrix, allowing gasses to pass through without restriction, yet should still reduce emissions to within legal limits.
