Yea have just bought some from fensport.
Have now got this eBay supplier saying I'm wrong n that the studs I've bought fit the front of the car and that the front and rear have different splines?
The fact that I am trying to fit these in the front and there too small is laughable.
Here's what he's said.
And he doesn't mention any of this in his eBay sale, even though his information is wrong!
That is fine, it is your choice where you buy your parts for your vehicle.
We just want to point out that for MR2 there are type size of studs as the front and rear is different in length and spline size from OEM.
The OEM front stud is longer with spline size of 12.4mm, the rear is shorter with a spline diameter 14.3mm
I think you are trying to replace the stud on the rear and you have bought the 12.4mm spline size studs which can only fit on the font.
Not many people knows this as most of them assume that the stud will be the same front and rear.
But actually there are a lot of vehicle has different stud front and rear despite the thread size is the same, the spline is different.
You are welcome to return the item to us and we can issue you a refund, however we are not responsible for the return coverage as the item is not faulty.
