Been to MR Toyota today
cvega666
Re: Been to MR Toyota today
Post by cvega666 »
I can report what i've seen when Luke (the dood above) did mine!
obviously, wait for the car to cool down!
- get a tray underneath the engine as you will loose coolant
- take off the bolt holding the oil dipstick and move it gently out of the way
- undo the 2 bolts on the side of the thermostat
- pop the hose off, but be careful to keep it upwards so you don't end up with everything coming out :)
- get the thermostat out, gently clean the hose with a wirebrush and a cloth
- put the new thermostat into the hose, but make sure the small air valve is on the TOP
- replace hose, bolt it back up
- bleed!
cosmos
Coolant
Post by cosmos »
Coolant Toyota Forlife anyway need two 5litre containers at £20 per tub, thow in a couple of O rings for radiator bleed screws just had mine changed at Roguemotorsport check their fixed prices your quote with thermostat seems ok.
cvega666
Post by cvega666 »
You dont need 10 litres of coolant if you're just replacing the thermostat. Obviously it doesn't hurt to change it if it hasn't been done.
If you're after a quick thermostat replacement, 115 for the job at toyota is ridiculous.
JDM-MAT
Post by JDM-MAT »
Thanks guys I'm going to give this ago next weekend
