Gizzmo wrote:Sometimes it will stay at 130 deg for a few minutes, sometimes it will drop in a few seconds.
When it does drop, it does so quickly.
Easy check.
Sort the cooling system levels out again.
expansion tank at the correct levels.
Stick a coke bottle at the expansion tank overflow.
and then take it for a hard boost session.
If you're running 1.5+ bar.
you're going to exceed the coolant pressure threshold and thus.
the expansion tank will get excess gas
/ fluid through it which will spill out.
In reality, no coolant should come out of the overflow of the expansion tank
( unless over filled
Like others have mentioned, the cavitation is caused by combustion gas.
.not pump impellar issues
( they're metal
) or flow rates etc.
this will either be through the head gasket or through a cracked block.
Temps will rise suddenly as you're displacing the coolant with gas around the block.
you'll feel the heater go cold before itshoots up
( early warning
The temp probe is a little slow to react in reality.
Could of things in the build.
History of the block.
Did it overheat before the rebuild
Where I'm coming from, you may have skimmed the head, new head gasket, but did you have the block decked.
it might answer some of the gas passing issues.
Either way.
moneys on combustion gas displacement, where its coming from can be only from two areas.
Dont forget to check the simple things.
loss of coolant.
The rad bleed nipple is prone to leaking.
mine leaked without realising it.
the coolant shortage at the front will cause considerable air locks within the system too.
So recap
-Check for leaks at the front
-Carry out said coke bottle approach
-Run the engine with the filler cap off, check for the rising bubbles
( when hot
) and stick a gas analyser over it to see if its carbon monoxide
Other things that will throw you.
You may start to see the water pump start to leak under pressure
Once the coolant system builds pressure, you may see a stream of coolant come from the water pump.
this will not be the reason but the resultant problem from the overheating.
When the block overheats, there is normally a lack of coolant around the block
/ pump.
This
"dry" running will score the carbon bearings in the pump which will then allow it to pass coolant under pressure
So before you react to the leak.
dont go through all the trouble in changing it out when its a downstream issue which has been caused by the overheating.
On that note too.
I advised strongly to anyone thats had overheating problems where you've boiled it over considerably to change the water pump too after rectification.
Block sleeving.
I've done it
These engines wont get the better of me.
I've split 2 blocks soo far.
One ran at a mere 1.3 bar.
the other 1.6 bar daily.
with a burst to 2 bar.
Luck of the draw for block integrity
