jimGTS wrote:ebc> mbc any day of the week.
I would agree jim, for full potential that a boost controller gives, EBC wins.
![Laughing :lol:](./images/smilies/icon_lol.gif)
Dale_V wrote:jimGTS wrote:ebc> mbc any day of the week.
I would agree jim, for full potential that a boost controller gives, EBC wins.But for
£20 an mbc will do most people fine and it's probably the cheapest BHP you could ever buy
Steve-O 2007 wrote:pritty easy to fit.
Locate the boost pressure pipe from the turbo that goes to the actuator.Cut this hose in half and the hose from the turbo goes to the in port of the mbc
(opposite the screw in bit) and the pipe going to the actuator goes in the other port of the mbc
(out port).
block the other pipe off thats going to the actuator.
Now Unscrew the screw as far out as possible to lower the boost.
You will get a manual with it as well most likely![]()
Steve-O 2007 wrote:
Dont know about using bolts, I found that when I put pressure down lines that had bolts blocking them off you would still get slight leaks from them(most likely due to the air going around the gap in the thread and out.
) I just used tight fitting round metal bar cut to size to block mine off.
