i have recently bought the hks evc 6
but i was one of the lucky few to get one of the limeted eddition 20th anniversery copper screen
(only 500 ever made) from a seller on ebay who was at the autosalon show when hks launched them, i dont no any one out of japan whith one of the copper screen models
after purchesing it i wonderd if i was out of my depth on how to use all the features i could of been more wrong it is amazing bit of kit, whith very easy setup after i installed it, i put the ignition on started the car, all i had to do was drive with no boost and under 3000rpm on 1st 2nd 3rd 4th until 5th were you had to give it full load to register your stock boost and it will also pick up a plot of your boost through the rev range it wil automaticly even out any iregular boost drops etc wich i thought was great
i then had to set my maximum boost
then what psi boost for when the overboost warning function would come on i.e for any reason for the boost to go over your maximum boost setting it will automaticly warn you with noise flashing etc aswell as drop and hold the boost back to stock setting
your target boost i.e you high boost setting in psi
then your wastegate either internal or exstenal
your
a boost setting/ 24psi high for dry weather
b boost setting
/18psi mediam motorway use
c boost setting/ 10psi low wet weather as i hav
ir also has Map Correction Mode
* Boost pressure can be fine tuned for: Throttle Position, RPM, Vehicle Speed, Throttle Position
+ RPM, or Throttle Position
+ Vehicle Speed.
i hav mine set for when im on b boost setting for motorway use the boost will only come in at 5000rpm or higher to save on fuel but the power is there for over taking etc
also for when i goto drag strip i can set amount of boost for each gear i hav 1st gear no boost for traction then 2nd at 7psi, 3rd 14psi and so on
the options are endless.no boost till a sertain throtle persision etc.
also i find good for the motorway on entering slip roads onto motorways is the Scramble Boost Function
* When the scramble boost trigger is depressed a preset boost increase will occur for a predetermined time
(0-60seconds).
so at a press of a button it will giv me extra added boost for when im goin on to a motor way etc witch i thort would be one of the funtions i wud neva use but i found my self using pritty offen more then usefull for a number of reasons
along whith
* monitored: Throttle Position, Engine RPM or Vehicle Speed.
Selectable Analog Monitoring
* The digital bar graph can be set to monitor: Boost Pressure, Throttle Position, Engine RPM or Vehicle Speed.
After Image Function
* Users can set the EVC to display the highest boost pressure reached for 3-seconds after the throttle has been released.
Peak Hold
* The EVC will store to memory and keep displayed the maximum boost achieved.
Data Lock
* To prevent accidental data changes from occurring, the EVC can be locked with a user defined four digit code.
Positive LCD display with LED Lighting
* Black foreground with white background and LED lighting provides excellent visibility during both daytime and nighttime use.
Dimmer Function
* Brightness of display can be adjusted for user comfort.
theres more im sure lol
as for the size it fits perfecty into the heater section on the centre consol like this
you can also plug it into your laptop for boost graphs,chaging setting sounds and loads more.
theres no other boost controller on the market that can do what this can do in my oppinion its the best there is hope this helps buddy
