Gear shift selector bearings! Well worthwhile!!!
Re: Gear shift selector bearings! Well worthwhile!!!
Ball bearing races are where the outer and inner races are stationary and the balls revolve so there is no direct friction on the selector pin, as opposed to a solid brass bush that would eventually wear oval through friction with the pulls and pushes of the gearchange to a non revolving bush without renewable lubrication. Your initial assembly grease plus brass rubbings would act as grinding paste where the softest material the bush would suffer. Only my opinion though for what its worth....
- IMOC Committee
That is more or less what I was trying to say in my post above.
IMOC-UK
- the only club to win
'Best Club Stand' at JAE more than once, and twice in a row!
