RobCrezz wrote:
I have never heard that the timing needs to be adjusted for 1.2bar.Everyone else normally says the standard 10 BTDC is fine for the base timing.
Luke checked my timing and its at 10 BTDC as normal.
No, that's very wrong
Basically the problem is that as you increase the boost pressure, the charge temperature in the cylinder rises on the compression stroke.
It can rise to the point where the air/fuel mix will spontaneously explode at the same time
This is called
If you've got the standard ECU and boost control still fitted, it will knock the timing back to stop this, and if that doesn't work, cut the boost.
What you want to do is to advance the timing as far as you can at the highest boost level you run whilst avoiding detonation.
Lots of detonation will kill ringlands and hotspots buildup
That's why running high octane Super unleaded is better than normal unleaded
To give you some idea
A rev3 starts with a base of 13psi and 10DBTDC
Either way, I'd get it checked on a rolling road.
You done a compression check?
Have a read back to Jeremy's post on the Inner workings of the Rev2 ECU, and what the ECU in particular does when it detects knock
http://www.imoc.co.uk/forums/viewtopic. ... ght=timing
