Is the VSV on the same vacuum circuit?
Turbo VSV
Have you had the inlet manifold apart at all
If I remember, the air con VSV
If this isn't connected up, then it'll be drawing air in
Turbo manifold
Blue_5 wrote:Hi JJ,
Ill pop the top off tomorrow and just doubel check theres no corrosion(theres none at the connector end).
Cars running now, fine as you like.![]()
I just don't like the thought of the cars new owner having a problem with it.
JJ wrote:Blue_5 wrote:Hi JJ,
Wouldnt halm!!
Often the connect stays clean.
its the water ingress to the top that causes the problem.
Sold up shop as well???!
I noticed that the vacuum pipe going to the stock boost gauge electronic sender didn't have a diode type thing on it, so put one on, thing is, the one I put on seems to be a two way diode![]()
Not sure if that would stop the car idling?
When the car is running(on throttle), no boost registers on the stock boost gauge, is this right?
Checked the resistance across the ISC valve and it seems out of range(about 30-40 ohms), does this mean it needs replacing?
the valve closed, but I could still blow air past it
- is that normal?
The only other area I can think of that might have a vacuum leak is the fuel injectors(I read another thread where air was passing by the injectors).
When I tightened the FPR, I noticed one of the injectors rotates in the rail which I didn't think was right.
I'm not going to be near the car til Monday now so will have a look at timing and stuff then.![]()
