turbokev wrote:I personally prefer big wheels,i like the handling characteristics,they may break away sharper but i find smaller wheels with higher profile tyres have a whippy feel to them,the flexy sidewalls seem to make the car feel unstable like a spring effect,whereas very low profile tyres are rigid.I find u can feel the breakaway point better due to their stiffer sidewalls rather than high profile tyres which have their own damping effect and dullen any road feel.Modern performance cars are using lower profiles than they used to,why would this be if it had a negative effect on handling?
Spose in the end tho its how u like ur car to feel thats important eh
This is true and find the same combinations i have tried mostly on Japanese lightweight split rims full trd/tein racing suspension
7&8" wide 16" volks rays with 20mm odd factory hubcentric spacers
205-50-16-225-50-16.
.as
turbokev says.
.bouncy unstable bit more comfort fair wet performance.
.Michelin pilot sport most expensive good
cornering grip
7&8" wide 16" enkei deepdish with 20mm odd factory hubcentric spacers
215-40-16-225-45-16.
.spot on steering grip lower front raised rear end more rubber is perfect all round in every way.
.cane it.
.grb451 Falken
directional excellent wet dry perfect balance makes everything work
how the mr2 likes to.
7,5&8.5" wide 17" gold advan rg circuit magnesium type metal alloy compound material?.
.this metal compound of rim made it very very hard and very circuit feel excellent handling made the teins work for their money but kept all suspension parts on the case.
.225-35-17-245-35-17
Falken grb451.
.here the wide low profile tyre n rims creates a wider track
very very stable n flat a bit less fun than above combination hard precise
no nonsense pro.
drive.
.manic response.
.all good.
8&9" wide 17/18" enkei split rims.
.lovely soft feel perfect speed nearly
off gps true speed so lost the over reading from speedo.
.this light weight
metal material makes a softer ride and is just perfect booting it through
a long sweeping roundabout feels right on it but possible feels slighly taller
than the cheeky 16's above but the wide track keeps the balance flat and
perfect awesome grip n stability.
.225-35-17-245-35-18.
.grb451 Falkens.
Never driven on stock rims not interested.
Teins ha coilovers set low with 10/16 rear rebound stiffness front 6/16
spring rate from factory front 4kg-rear-8kg
Tyre pressure front 32-33 rear33-34
4 wheel laser full suspension geometry set up fast road as per mr2 settings being fairly neutral not over set per say Jonb track where tyres
are chewed but grip enhanced.
