In my case I'm fairly sure the TPS problem was actually down to corroded connections on the TPS multiplug, but a little way back from the boot itself making it tricky to isolate.
Jon
boondougal wrote:this is not getting any better..
I got the wife to crank the engine over as i put the induction bit of my timing light on the HT leads to each cylinder and each one flashed so there should be a spark.
SuperRedMR2 wrote:Sorry I did read that part, then forgot it immediately!!!
Leads in the right order? Most of the time its the simplest of errors which are overlooked.
boondougal wrote:
My understanding is TDC is TDC, ie 1 and 4 will be at the top of their Stoke, the vital thing would then be the dizzy.
boondougal wrote:
I have not had the belt off since it ran before messing with TPS and the dizzy so tbh I don,t think I am 180 degrees out.
