[Mk2] [Turbo] Starting build
- IMOC Committee
Re: [Mk2] [Turbo] Starting build
Adding gearing for the dry sump oil pump?
IMOC-UK
- the only club to win
'Best Club Stand' at JAE more than once, and twice in a row!
Its because of the dry sump but nothing to do the dry sump system
ashman wrote:Fitting a ring gear over a cam belt idler.
Why? Not sure..
And what is the ring gear from? What do I not need any longer now I have the dry sump?
new oil pump sprocket with bearing inside to stop pump operating
(using original pump gear machined to accept idler bearing presumably)
should get this thread moved over to member profiles/project cars where followers will be able to find it easily.
gavinda wrote:new oil pump sprocket with bearing inside to stop pump operating
I have no need for the stock oil pump but I do need the pulley or I would have to get a custom cam belt.
With no oil inside the pump it would not take long before it all seized up.
I can remove the loose part of the pump but the bearings in the front cover are lubricated by the oil in the oil pump.
So I now have an idler pulley with the outer of the oil pump drive fitted over it, this will allow me to use a stock cam belt and the idler will be bolted in the same place as the oil pump drive came through the oil pump front cover.
gavinda wrote:should get this thread moved over to member profiles/project cars where followers will be able to find it easily.![]()
Yes you are right there.
Toxo, can this thread be moved to the right place please.
Thank you
awesome engine build thread buddy, love engineering threads like this
- IMOC Committee
Thread moved as requested!
IMOC-UK
lowslowandold wrote:awesome engine build thread buddy, love engineering threads like this
Thank you but the building is yet to start, all I have are boxes of parts and bits and keep losing them as my son moves things around the workshop.
Must get on with this now, as soon as it get warmer
Oh just got some more in the post today.
ID 1000 this time.
ID 1000 this time.
Head all set up for some work with the mill
- IMOC Committee
Extreme!
IMOC-UK
this will end in tears.
Its only to give some clearence to the high lift cam
stephano wrote:this will end in tears.![]()
It'll be fine- did the same on my head to fit the cams.
It started with pain as you know but will be ok if I take it easy
New 5SFE oil pump came today.
I need this to hold the crank sensor, just the casing, the oil pump bit will not be pumping anything.
Before and after clearance work for the 11.5 mm cam lift
