No, I do not like them and the boot will have the dry sump tank in it.
It will be a large charge cooler system with an ice tank in the boot and front rad
calum4492 wrote:u considered water/meth? i plan on getting some but cant afford it right now
I will not need water injection as the engine has been designed correctly and will not knock.
Water is only needed when an engine is detonating, if it is injected any other time the engine will lose power.
I have just got the block back after a mod or two to it.
Had some work done on the head so I can fit a cam senser, just need the maching work done now.
Need to start the first trial build of the block but the workshop is a bit damp at the moment so not sure I want to start that yet.
Mind if I ask who you got them through bob and what you paid?
Cheers.
TOTB 2010 Rwd top speed, 1/4 and shootout winner.
10.7@142 on R888 street tyres, 10.3@134mph on slicks,
9's on slicks to come, with a clean full throttle pass! Goal of 0-150mph in a 1/4 of a mile....
calum4492 wrote:2000cc? or jus a model name?
ur making my 1150's sound like paps
Probably idle and run aswell/better than your 1150's too
Cheers.
I got them from Ty Saxon in the USA, they are new and came with a large fuel rail and -10 fittings. Had been fitted but never used.
I think the cost with shipping was around $950
