toxo wrote:If you're pumping the wrong way then you will get an eye full of coolant when you run the pump without the cap on top of the core!
Small kinks(45 degrees say) won't be too much of a problem as long as your pipe is strong enough not to warp when hot.
allan welsh wrote:kinks restrict flow and provide back pressure to the pump.best to get them sorted
Thanks guys
They are small kinks with where the pipes run quite close to each other.
Im hoping bleeding wont be too much of a pain, Im using a motorbike
