Nathan
Century Motorsport wrote:Found some pics of the engine after the cracked block today..
RyanRs wrote:Neeethanull.
what are the multi ignition leads from? i assume they wire straight into your EMS which is then re-programed for multi coil as apposed to Dizzy or DIS
Leakie Tbar wrote:Nathan you could have used a 1998 5SFE bottom crank gear and pick up bolts straight on![]()
are you using a wasted spark system![]()
karammander wrote:hope this gives you ideas regarding your pick up.
cheers karam
