Right, being doing some more work on the car.
I decided to sort out the boot loom.
My aerial has been removed and blanked off, with the 6 wire plug hanging, where it used to plug into the aerial.
It also had all the additional wiring for the 4 brake/tail light wiring including 2 relays, which is all no longer required.
The boot loom also looked untidy, so, I unwrapped the whole thing:
I cut the plug off the old aerial wiring, and pulled back the wires, and removed the aerial earth wire:
These were then cut back, insulated, and wrapped up.
Next, I bought tie wraps, 10mm conduit and Tesa loom tape:
Once I'd finished removing the unwanted wiring from the boot loom, I tested what was left and made sure everything worked as expected, before wrapping the loom!
I then began putting the wiring into the conduit and following up with wrapping in the Tesa tape.
Once the loom was finished, I used black tie wraps where possible to secure it the against the chassis.
And the end result, which I'm pretty happy with, a tidy looking boot loom:
I've also put 12mm blanking grommet in the old aerial drain tube hole in the boot floor.
And that's it for now!
