Gazza_DJ wrote:jimGTS wrote:
Also met another chap, couldn't remember his name, sure he's a member on here.They both were running similar 350/360hp levels.
Even had a run out against the chap with the white one!
[url]http://url.photobucket.com/albums/v326/jimbob_uk20/257D2C1D-83EA-4DE8-9FFF-973A7122E945.jpg
[/URL]
White and black panda car is Aaron, don't think he uses the forums much, posts on the FB groups quite often.Bit of a monster hiding in that engine bay, plenty more headroom for more boost!
jimGTS wrote:
yeh had a good chat, mentioned he was running a holset turbo, 1.5bar and 360ish hp.
ironing out the setup, then transferring it to a clean shell.![]()
heads up was fun
not sure what his best time was on the day
craig wrote:Good stuff Jim.Glad all is well.
Looking good!
steven63 wrote:as regards the blitz ECU they were made for the jap market were they have 100+ octane fuel that is not availalable in the uk, blown knock sensors are common on cars that use these ecu in the uk, after removal of the cylinder head many have also noted damaged pistons, if the tvsv is left connected they raise the boost using this system
auzzam wrote:I'm going to be there on Saturday at the japshow test day, any one else?
Al-sw20 wrote:What do a 600hp Supra and a 300hp MR2 have in common?
They both run 12s![]()
