[Mk2] [Generic] how to remove side vents ??
Kubus
Post by Kubus »
as above - cheers guys.
toxo
Re: [Mk2] [Generic] how to remove side vents ??
Post by toxo »
You need to remove the trim strip above the vent. There's a small screw on the lip of the trim in the wheel arch, a 10mm bolt inside the wheel arch, and a 10mm bolt inside the car, behind the trim that hides the seatbelt mechanism and rear speaker. However be warned! One of the bolts in the trim strip is very long, so you need a deep 10mm socket to be able to get it off. The ones Halfords sell as 'deep sockets' are deep enough.
Once that's done there's another 10mm bolt inside the wheel arch at the bottom, holding the side vent on. It's in the bottom corner nearest the wheel.
HTH :thumleft:
slipping clutch
Post by slipping clutch »
you will also find on the trim strips 2 "protruding lugs" that push into the body work - DONT just pull on the ends of the trim once you have taken off the nuts - ease your fingers along the trim from the ends and work the trim free - just pulling on it will bend the trim and then you can never get them to look as good as they did when you re fit them - found this out the hard way #-o
JohnnyC
Post by JohnnyC »
