Quick question, when you say two runs I presume this is 2 seperate runs? 1 run consisting of 3 shoot outs to get the average of the 3? If it is 2 completely seperate runs would I have time to drop a different tune on?
This will be an excellent op for me to check my semi-open look tune vs my stft tune and particularly interested in checking out my AFR's to ensure they are still consitent with the last time I checked back in Feb.
Definitely up for this as its only down the road
(despite moving to Swindon!) as it would be good to check out a new rolling road
(usually use Charly down at Surrey RR).
What runners are they on? Dynodynamics etc? Also the results, I'm only interested in whp not flywheel, will the results be given as wheel or flywheel
(the latter being a pluck figure from air type result
ETA managed to get car out of storage and then had a look as to how I ended up with the notification! This thread
http://www.imoc.co.uk/forums/viewtopic. ... sc&start=0 was how I registered here so I'll be able to prove it really was me
See you guys on Saturday
