But I found quite dramatically I had a fuel leak.
Leaking from the bolt
Hard to see if any where else but was quite allot of fuel collected on the TVIS unit by the time I turned off so possibly leaking from underneath the rail somewhere.
This bolt was on tight so tightening did not stem the flow.
Should there be some sort of gasket here?
Any one help with what I should check.
