chrismanchr wrote:one of your pistons seems to have put on alot of weight since removal
i dont think any rebore is gonna fit that one in ! lol
Lol, it's actually a piston out of one of these devices:
how much did the hone cost?
Don't know, but not much. You can do it yourself if you want. It's just that I have an excellent engine rebuild place less than 1/2 a mile from my Dad's house so I let them do it.
about the bore clearance ,ive heard of race engines having so much piston to bore clearance that the pistons will move quite alot in the bore (and sound like a ball in a bell) but then again they never get started up cold ,but its quite amazing what you can get away with ,I looked at your measurments and although I'm not an engineer ,i think they look fine ,Ive seen a few mr2 engine rebuilds in the forums and other websites and ive never seen one yet need a full rebore
The engine man reckons it is absolutely fine. I will be test fitting the piston rings later and checking the ring end gap. I was concerned about the wear at the top of No.3 piston but he has reassured me the compression will be fine. He's very very well respected and therefore I'll go with his advice.
System-G wrote:chrismanchr wrote:,Ive seen a few mr2 engine rebuilds in the forums and other websites and ive never seen one yet need a full rebore
You obviously didn't read Anna & Speedy's thread then
Yes, that original rebuild was truly appalling I reckon it was done by a run of the mill garage, there's no way they knew what they were doing. It should have been done by a proper engine place ()
