whoozy wrote:paul thought id have a little play about with the turbo system..
this involves using an aftermarket actuator with its spring modified to give way at 2psi,this way we can control boost to the actuator electronically and have finer control over the max boost
whoozy wrote:Now its getting mapped right lets see if2bar
is on the cards
EarL wrote:whoozy wrote:Now its getting mapped right lets see if2bar
is on the cards
Hang on, is the motor built with forged internals??If it's not, and you run it at 2 bar, that'll be the shortest lived V6 on the planet!
If you're going to fit a GT35, a few other things are going to have to be changed as well.![]()
Injectors for a start.
.all the best Whoozy.
EarL.
