[Mk3] [NA] Mk3 Parts
Mr Flibble
Post by Mr Flibble »
Please can anyone recommend a decent company that sells parts cheaper than Toyota for a Mk3 Roadster (UK)?
I will be needing a new set of front discs including pads and two exhaust brackets with the 'grommits' (if that's what they are called) that fit behind them, the reason I need two brackets is because it has the TTE twin exhaust.
Of course any advice to help me replace these parts would be greatly appreciated.
HighwayStar
Re: [Mk3] [NA] Mk3 Parts
Post by HighwayStar »
You could try Fensport mate. Only people I know who do stuff for the Mk3 unless Rogue can help with the brakes?
R.
Mr Flibble
Will take a look, thankyou :)
Return to “MR2 MK3 2000-2007”
