Blitz Sus Power Air Filter Lm
K&n 57-9001
A'PEXi Power Intake Filter 3S-GTE Turbo
HKS Super Mega Flow Air Filter
Which would b best for my rev2 turbo?
steve b wrote:any they're all the same effectively
steve b wrote:in terms of performance i bet they are near enough the same.![]()
summ0004 wrote:Ive had a HKS, and blitz and there is sod all difference between them in terms of power.In fact there isnt that much of a big difference compared to an airbox either, its mostly about noise.
Cant comment on filtration on them, but as long as it filters well enough for the engine i dont see how any theoretical simulated test is relevant.
Paul
We've now developed a carbon fibre airbox/shield.Functionality with bling!
stevel wrote:We've now developed a carbon fibre airbox/shield.Functionality with bling!
Are you planning to market these or is it a one off? I have been looking for someway to section off my apexi.
Chris 'aka rustboy' Ammon wrote:i think the best option is to replace the standard air filter with something else, that way the plastic can still act as a bit of hear shilding.
i was considering getting the TRD filter at MTTE at one point as it looked good more than anything else
MR2Mania wrote:steve b wrote:any they're all the same effectively
No, they're not.Not in terms of filtration, anyway.
And if you've ever seen how badly the compressor gets damaged from bad filtration, you'll appreciate that.
Terry wrote:This is what a dried up HKS filter did to my compressor wheel.
The bits of filter chewed and bent the ends of the blades.![]()
