Just had a CT20b fitted to my rev 2 with a decat pipe.
The garage didn't know what to do with my cat senor, so wired it directly to my aftermarket Exhaust Gas Temp sensor!
strangely enough this doesn't do much.
So 2 questions:
1.
What should I do with the Cat Temp Sensor to get the light to go out?
2.
With the CT20b I was boosting to
.93 bar, then got 1.06 bar and the engine management light came on.
Now it won't go past 0.16 bar before juddering
(is this the fuel cut), and do I just install then fuel cut defender and reset the ECU
(by removing the fuse)?
