What more can i say .remapped my car same boost as it was mapped before at by someone else ,made an exta 45bhp and 20 lb/ft
I will not consider anyone else to do mapping again after seeing ryans work
Recomended
Thanks Guys
Also just to add we popped marc's car straight on the dyno to see how it faired to the last dyno sheet at 15psi and then what it was running at 1.3bar and then proceeded with the remapping just incase anyone thinks he gained the extra power and torque from just a different dyno.
We also found Piper have got their timing instructions spot on as played with the cam timing also and found no gains from adjustments and tweaks.
