sounds like an optical angle
(and therefore velocity) encoder:
http://abrobotics.tripod.com/Ebot/using_encoder.htm
How smashed up was it? If the disc is still in one piece, you should be ok
- they are normally enclosed in automotive applications to stop junk and crap cloging the slots in the disc
(hence screwing up the angle measurement).
Once you're happy you've got the code wheel
(circular bit with slots) and the encoder
(small black box with wires going in!) sorted
(if you can't see the encoder and it works
- leave it!) then if you can, a piece of gaffer tape to hold the casing together and to keep the crap out.
HTH,
Anna
