Bought it from ebay and wan't to make sure it's for my ride. OK. My ride is 92 JDM 3s-gte engine with afm..
serial number of PFC is:
PFC SW21 9807-0003
board number is:
FC3-A 05984-L5001-00
in one part got number in paper:
FC3-SW21-2
and one another got:
CEX-9610-085-SW20
[Mk2] [Turbo] Which apexi PFC I got?
Re: [Mk2] [Turbo] Which apexi PFC I got?
Please. If someone who has PFC for rev2 could look in his PFC if any of these numbers look at same. Or could it burn any sensor or ecu if I just plug it in.
http://www.imoc.co.uk/forums/viewtopic. ... light=murf gives some number but not sure if any use to you
Thanks, but no help. I think that sw21 mark in my pfc is that thin what counts
Has apexi made rev2 pfc it self or are there only ap engineering for that.
And if here is someone who has pfc which serial number starts sw21 please please send me pm or something.
Got post from apexi dealer that this is real deal rev2 PFC, but he wrote that I need some sensors and wiring.. Could someone told me what I should do and what sensors could I use. OEM or could I use some cheapers things.
um, pretty sure only the AP ones are for Rev 2 ! Have a word with JimGTS, he had an AP PFC before swapping to the rev 3 ECU.
IF you have a AP engineering power FC its a direct plug and play on a JDM rev2, late 91 to late 93 car...
IF you want to ditch the AFM you can on this PFC model, youll just need to splice into a couple of the AFM lines and fit AIT and MAT sensors, fit a rev3 map sensor and just change the options on the hand held commander.
IF you have a USDM car, then im pretty sure your going to need to rewire it to take a rev2 JDM harness....
if it is a gen3 POWER FC, then you need to certainly rewire to a jdm rev3, fit numerous OEM sensors from a rev3
i can check the codes on both my AP and gen3 power FCs tonight!
My ride is -92 feb JDM...
best way to find out is to plug it in see if it runs
i had a rev2 PFC AP engineering but it did not say that anywhere and there serial numbers ment nothng.
so i plugged it in and hey presto it worked. as far as i know its been used in a rev 2 now all mapped up properly
simmo
simmo
And if its not plug n play and it needs those sensors and wiring can it burns something??
wouldnt like to say, but i wouldnt have thought it would start....
whether or not it burns anything, is pot luck i would have thought
Oh I forget one thing... The PFC got adapter harnes... It was in rev 1, and there is only few wires that switch places... Should I use this?
i'm no expert on MR2 (wrong forum for me )
but from what i've read the SW21 9807-0003.
My Toyota EPC does not have this listing... Is that a USDM vehicle and uses the normally aspirated 2.2l 5S-FE engine?
> > was there ever a 3sgte built July 1998 > March 2000 on a SW2# chassis?
you can plug it in, if it is the wrong one it will NOT start and will NOT burn anything out.
however if it does start you know its the right ecu but i wouldnt recomend running it untill itis mapped
simmo
simmo
OK. I plug it tonight.. And if it burns I send you simmo a repair bill... I get playing some electric god and find out those wires which came with the unit is from us st185... So I leave it alone...
it will be ok mate trust me
It starts and it didn't burn...
there you go, its all good now get it mapped properly
