hi all cant seem to search for a certain subject any one else found this?? any way of the beaten track.
Ive got play on my rear wheel bearing so ive starting stripping it down to change it ive removed the hub and started by removing the circlip, not sure which way do i press the bearing out??? any pics would help many thanks
[Mk2] [Generic] wheel bearing
Re: [Mk2] [Generic] wheel bearing
press the bearing out the way the circlip came off. the circlip is there to keep it in place, so the bearing comes out of the same end as the clip
simmo
simmo
What you pressing it out with Lol
um whats funny about that you freak?
you confuse me you hippocrockapig of a fag?
thanks for the help mate and what is funny about what im pressing it out with
You'll need a garage to press it out mate, my local Mr T only charged me £20 to press out and re-fit mine, might be worth a go
Even if you do get the old one out you'll probably damage the new one putting it back in!
Steve
Steve
Try a 1 ton Press you will never in a million years move the outer trace without bashing the xxxxxx xxxx out of it with a chisel and hammer,
and presuming you didnt know which way the bearing came out you anit got one ?? or I might be wrong.
simmo490 wrote:um whats funny about that you freak?
We could use your massive head large loaf to press the bearing out
rent boy!!
no i aint got one yet i was going to get the bearing out and take it down to my local bearing specialist and see how much they can get one for. ive got the advantage of having my dads workshop with a 100 ton press so shouldnt be a problem getting it out
That'll do it nicely
Whatever you do though, don't use the brake caliper tabs to support the hub or you'll either bend em or snap em off!
