[Mk2] [Turbo] Recirc valve
TRDave
Post by TRDave »
Could anyone point me in the right direction to what recirc valve i could use with a TD06?
I currently am using a Blitz bov but want to be rid of the whoosh if possible??
Dave
2Crooky
Re: [Mk2] [Turbo] Recirc valve
Post by 2Crooky »
What intercooler are you running???
You should have a return feed on your intake pipe much like the stock unit that has been plugged or covered. If you have the stock IC hot pipe then you can run any recirc BOV and plumb it back to the stock location with a bit of suitable hosing.....
Post by Martin F »
TRDave wrote:Could anyone point me in the right direction to what recirc valve i could use with a TD06?
Dave
the stock valve should suffice..
what flywheel power are you running ?
TRDave
Post by TRDave »
Running uprated Intercooler with a TD06 ATS Kit.
Wasnt sure if the standard would be up to it?
rookie-racer
Post by rookie-racer »
oh hell yeah... a while ago i scrounged the original recirc valve from a supra tt thinking it would be a upgrade [-( the original one on the esgte is bigger than the supra one :shock: which can recirc enough air to feed a boosted 3L lump where you are only looking at a 2L lump :thumleft:
