Jim i should be able to help
Right: Your main objective is to get the afm seperated from the air filter housing, so start by:
1) Undoing the pipe that the afm sits in, this should be a phillips screw to slacken it off.
2) Unclip the air filter box, will be 4 clips, these can be done by hand, now you should be able to lift the top of the airbox out with the afm attached so you will see the filter.
3) Remove the air filter, and you need to undo 3 bolts on the underneath that holds the casing on to a bracket,
(use a long rachet as these are quite stiff.
Now all you need to do is sort the afm out which you removed earlier, basically there are 4 bolts connecting the afm to the filter housing, undo these and bingo you have a seperated AFM.
There is a big black plasticy thing that sits on the inlet,
(resonator), this lets air into the original air filter, you don't have this so i removed it, you can choose what you want to do.
The problem with this is that the Apexi sits lower then the air coming out so i will make my own pipe up later on.
All of the original pipe work will go back on minus the air filter housing, its a bit of a squeeze and you may have trouble getting the brackets lined up but you will work it out
Hope this has been of help to you mate
Any questions fire away
Ross
