and metalic rattling is ......
CosmosblueMR2
Re: and metalic rattling is ......
Post by CosmosblueMR2 »
UPDATE:
Leeroy.. so far <touch wood> the new bolt has FINALLY sorted my rattle \:D/
not bad for under £2 ! :idea:
Leon.
Post by Leon. »
\:D/
I've got one on order \:D/ \:D/ \:D/
:twisted:
cantfindausername
Post by cantfindausername »
Can someone post a pic of the part that you're replacing?
***RIP Car13 ***
*** Now in an Evo ***
CosmosblueMR2
I've still got a little rattle on idle - but that's the clutch bearing as it goes when you depress the pedal - and you only hear that when at idle as i say - at least i know what that is, so not bothered about a new bearing or clutch :eye:
got a squeaky clucth too - pivort not greased enough on install i guess - oh well lol... 2 rattles left - one day one day :lol:
typical MR2 squeaks - don;t you just love em
Club Tropicana
Post by Club Tropicana »
My rev3 makes this metallic rattling noise! where does this bolt go?
CosmosblueMR2
Club Tropicana wrote:My rev3 makes this metallic rattling noise! where does this bolt go?
in the bearing on the rear axle/driveshaft...
CosmosblueMR2
cantfindausername wrote:Can someone post a pic of the part that you're replacing?
it's on page 1 of this thread... a bolt.
Club Tropicana
Cheers. Can it be seen from the rear/front of the car?
nick200
Post by nick200 »
cosmos blue, fingers crossed that was your problem too !
£2 to fix :D
Club, it is at the rear of the car as the drive shaft comes out of the gbox on the drivers side - but really you need the car up on axle ramps to slide underneath to get at it.
Leon.
Post by Leon. »
Well finally had my new bolt fitted and its early days but think its silenced a noise!!
Clutch release bearing is pretty new so doubt its that. Only others noises I have now that are from the gearbox - worn bearings :roll: ](*,)
nick200
Post by nick200 »
hey Leeroy, that sounds encouraging ....
if only gearbox bearings were as cheap to fix !
Leon.
Post by Leon. »
Yeh, try more like £500-£1000 depending on what bits need doing 8-[
S11NY_P
Post by S11NY_P »
Where do you put this bolt tho, can anyone post up any pics of where it goes as I am a bit dump when it comes to cars, Would I need one or 2 of these. :(
Suny
tubby_tony
Post by tubby_tony »
http://www.mr2-tech.com/bgb/mechanical/ ... d_axle.htm
Page SA-52 Rear Drive shaft 3sgte engine section. At the top of the image you will see the bearing bracket stay that the axle goes through. This has the snap ring to the left of it and to the right a single bolt with a dotted line showing where the bolt goes in the stay. This is the bolt. You just need the one and it is easy to replace without removing anything else once you are under the car.
ferrit
Post by ferrit »
Are you guys ordering those from JeffD?
CosmosblueMR2
ferrit wrote:Are you guys ordering those from JeffD?
Toyota do them for about £2 :eye:
Car now Sold :cry: damn 5th Lumber Disc !
